System Time
The System Time plug-in creates a variety of time and date settings based on the system time. This plug-in adheres to the standard IEEE Std 1003.1, 2004 Ed.
System Time Properties
format (aAbBcdDHIijlmMpSUwWxXyYzZ/:,.): Sets the format of the system time.
Language: Sets the language format of the system time. Options:
Default (system specific)
English
German
Norwegian
Seconds offset from system clock: Sets the number of seconds the system clock should be offset (default is 0).
Hours offset from system clock: Sets the number of hours the system clock should be offset (default is 0).
System time zone: Sets the system time zone.
Show Time Zone: Shows the result of the system time zone.
Lower Case Text: Shows all text in lower case.
Time Zone: tzn[+|-] hh[:mm[:ss] ] [dzn]
tzn: Time zone name, e.g. PST
hh,mm,ss: Offsets from the local timezone to UTC (not the reverse).
For time zones ahead of the set one, the time difference is negative.
For time zones behind the set one, the time difference is positive.
dzn: Daylight-saving-time zone, e.g. PDT
Examples: EST5EDT, PST5PDT, GST-1GDT
