Event Pool
A new event notification system allows different objects to emit and/or listen for events. The event pool tracks all registered objects and possible events from the command line. To enable debugging of the new event system, send the following command:
// activate / deactivate debugging (prints message on console for each fired event):send EVENT_POOL*DEBUGGING SET 1
Other commands allow the event pool to fetch a list of registered objects which emit events:
// get list of all objects which have registered some events (which may be fired at some time)send EVENT_POOL*REGISTERED_OBJECTS GET// get list of all registered events of a specific objectsend EVENT_POOL*REGISTERED_EVENTS GET $objectname// example:send EVENT_POOL*REGISTERED_EVENTS GET #727*STAGE// get list of all registered objects+events and number of registered callbacks:send EVENT_POOL LISTBuilt-In Events
For now, the following objects have built-in events:
Stage: (onStarted, onStopped, onDirectorStarted, onDirectorStopped)
Superchannels: (onArmed, onDisarmed, onTransitionStarted, onTransitionStopped) and its subchannels (onAssigned, onLoaded, onCleared)
Gfx channels: (onPreSetObject, onPostSetObject)
Editors: (onPreSetObject, onPostSetObject)
Scripts: (defined by the script itself)
Additionally, Superchannels and Scripts can be configured to listen on events.
Technical Notes
Generally, an event can have an arbitrary name (e.g., "onLoaded") and can be sent by any object. Scripts and objects can also listen for specific events and are notified whenever that event has been triggered.
Additional notes:
Potential events must be registered by sending objects before they are emitted (because listeners can only register to known events).
The name of an object can be chosen by the object itself on creation (e.g., "SUPERCHANNEL1" or "script1") but it is always preceded by the object id of the scene. Example: "#199*SUPERCHANNEL1".
Note: Aliases like MAIN_SCENE are not allowed.
A KeyValueMap (Stringmap for scripts) can be attached to an emitted event.
Sample Scripts
Scripts can be used to emit events and to listen for specific events. See the sample scripts below.
Emit Events
sub OnInit()Dim events as Array[String]events.push("OnTriggered")Eventpool.registerEvents("script1", events)' use commands EVENT_POOL*REGISTERED_OBJECTS GET and ' EVENT_POOL*REGISTERED_EVENTS GET sceneID*script1 to ' verify that events are registered when script is active' and that they are automatically unregistered when script' is stopped/modified' use EVENT_POOL*DEBUGGING SET 1 to' see which events have been firedend subsub OnInitParameters()RegisterPushButton("test-button", "press here", 1)end subsub OnExecAction(buttonId as Integer)if (buttonId = 1) thenDim params As StringMap' now emit our eventEventpool.emitEvent("OnTriggered", params)' this fails, because we have not registered the event:'Eventpool.emitEvent("OnBlabla", params)end ifend subListen for Events
sub OnInit()dim sceneid as Stringsceneid = cstr(scene.vizid)' Register as listener for 3 events of superchannel1 / subchannel Aeventpool.registerAsListener("#" & sceneid & "*SUPERCHANNEL1/A", "onLoaded")eventpool.registerAsListener("#" & sceneid & "*SUPERCHANNEL1/A", "onAssigned")eventpool.registerAsListener("#" & sceneid & "*SUPERCHANNEL1/A", "onCleared")end subsub OnEvent(objectName As String, event as String, arguments as StringMap)'println("GOT EVENT!")'println(objectName)'println(event)'println(arguments)if (event=="onCleared") then material.color.red = 255 material.color.green = 0elseif (event=="onAssigned") then material.color.red = 100 material.color.green = 100elseif (event == "onLoaded") then material.color.red = 0 material.color.green = 255end ifend sub
