Connector
This plug-in is useful to connect two objects with a line in a required color and width.
Note: This plug-in is located in: Built Ins -> Geom plug-ins -> Default
Connector Properties
-     Use LOD: Enables/disables dynamic level of detail.
-     Container 1 and 2: Placeholder for container 1 and 2. Drag the container onto the drop zone. Click R to remove the container.
-     Connection Point 1 and 2 By X, Y and Z Axis: Sets the X, Y and Z-value of container 1 and 2 where the line should start. Can be set to Min, Center, Max, CenterBB or Origin.
-     Line Width: Sets the width of the connecting line.
-     Drawing Mode: Available options are Line and Mesh.
-     Line Color: Defines the color of the line.
-     Border Thickness: Applies a border with the thickness determined by the value.
-     Border Color: Defines a border color.
To Connect Two Objects
-     Create a new group and add the Connector plug-in to it.
-     Create two new group containers and add a geometry object (e.g. Cylinder and Cone) to each group.
-     Open each container’s transformation editor and move the objects a part.
-     Add a material and/or an image to the geometry objects.
-     Open the connector plug-in editor and drag and drop the two containers to the Container 1 and Container 2 placeholders, respectively.
-     Adjust the color line.
-     Open the Connector plug-in editor and play with the settings.
-     Add more objects to Container 2 and animate it.
-     Scene Editor Scene Editor Buttons
-     BoundingBox plug-in
