Analog Watch
The Analog Watch plug-in lets you create a real-time animated clock of objects.
Note: This plug-in is located in: Built Ins -> Container plug-ins -> Time
Analog Watch Properties
-     Mode: Sets the mode. Available options are Hour24, Hour12, Minute, Second and Off.
-     Smooth: Ensures the clock hands rotate smoothly. Check this button to enable smooth rotation. Hour hands always rotate smoothly, so this switch is inactive if the plug-in is set to Hour24 or Hour12 mode.
-     Offset: Changes the rotation offset. 1200 usually is equal to a rotation of 0 degrees. -     1 hour in Hour24 mode: 15 degrees.
-     1 hour in Hour12 mode: 30 degrees.
-     1 minute in Minute mode: 6 degrees.
-     1 second in Second mode: 6 degrees.
To Create an Analog Watch
-     Add a Circle geometry to the scene tree, add material to it, and name it Clock.
-     Open the Circle editor and set scaling to 2.0.
-     Add three Arrow geometries as Sub-Containers of the Clock container, add material to them, and name the first Hours, the second Minutes, and the third as Seconds.
-     Open the Arrow editor for Hours and set the following properties: -     Style1 to Flat.
-     Width and Arrow Width to 4.0.
-     Percent to 30.0.
-     Open the Arrow editor for Minutes and set the following properties: -     Style1 to Flat.
-     Width and Arrow Width to 3.0.
-     Percent to 40.0.
-     Open the Arrow editor for Seconds and set the following properties: -     Style1 to Flat.
-     Width and Arrow Width to 2.0.
-     Percent to 50.0.
-     Add the Analog Watch plug-in to the Hours, Minutes and Seconds containers.
-     Open the Analog Watch editor for the Hours container and set it to Hour24 or Hour12.
-     Open the Analog Watch editor for the Minutes container and set it to Minute.
-     Open the Analog Watch editor for the Seconds container and set it to Second.
