Control Audio
The Control Audio plug-in enables the operator of a control application to choose a sound clip.
To expose the different properties, and change the audio file in one of the control applications, simply add the Control Audio plug-in to the same container as the Audio plug-in.
Control Audio Properties
Director: Sets the name of the stage director the audio channel is located below.
Audio Key Frame: Sets the ID/name of the audio clip Key Frame.
Note: It is mandatory to add Director and Audio Keyframe name.
Important: Make sure the audio clip name does not contain any white spaces.
