CFX Plus Plus
The Container FX Plus Plus plug-in allows you to set a number of effects on a container’s set.
Note: This plug-in is located in: Built Ins -> Container plug-ins -> ContainerFx
CFX Plus Plus Properties
Position Wrap
Extrapolate: Continues the direction of the spline when set above 100% or below 0% of Path Position.
Clamp: Stops the string on the spline endpoints.
Repeat: Causes the string to move to the other spline endpoint as soon as it moves over the endpoint.
ContainerFx: Positions containers by the relative spline of each container using the ContainerFx parameters.
Scheme Type: Defines how the container-set looks at 0% and 100% progress.
In -> In: at 0% first container is at the beginning of the spline, at 100% last container is at the end of the spline.
In -> Out: at 0% first container is at the beginning of the spline, at 100% first container is at the end of the spline.
Out -> In: at 0% last container is at the beginning of the spline, at 100% first container is at the end of the spline.
Out -> Out: at 0% last container is at the beginning of the spline, at 100% last container is at the end of the spline.
Progress (%): Animates the progress of the effect(s).
