Control SoftClip
The Control SoftClip plug-in allows the user to control and browse for video clips played in Viz Artist using the Soft Clip plug-in. Simply add the control plug-in to the same container as the SoftClip plug-in. Further, specify a Field Identifier and a Description.
Control SoftClip Properties
This plug-in does not have any properties or parameters except those that are common to all plug-ins.
