Viz World User Guide
World Image Refresh
The plugin can be found in the folder: Viz Artist 3: Built Ins -> Container Plugins -> Weather.
The WImageRefresh plugin is placed on a map container and when the map is changed the WImageRefresh plugin will refresh objects residing under the map container. This action will cause all the geographically referenced objects, under the map container, to recalculate their position and move to the correct position according to the new map.
This plugin has no parameters.
