Viz World User Guide
Version 17.0 | Published March 11, 2019 ©
Installing Photoshop Plugin
The Viz World Photoshop Plugin is used to integrate Viz World and Adobe Photoshop files. Maps created with the Photoshop plugin will create a new file with separate layers for every feature and detail on the map.
The scripts which are installed as part of the plugin are used to:
Configure the different settings of the Photoshop Plugin.
Open Map Editor Classic to select the desired map.
Create the final Adobe Photoshop file and layers, based on the selection and configuration.
Installed Files
The Photoshop plugin is installed under:
C:\Program Files\Adobe\Photoshop\Plug-ins\Import-Export or
C:\Program Files (x86)\Adobe\Photoshop\Plug-ins\Import-Export
The file that is installed is
VizrtMapImport.8ba
The scripts are installed under:
C:\Program Files\Adobe\Photoshop\Presets\Scripts or
C:\Program Files (x86)\Adobe\Photoshop\Presets\Scripts
Important
Newer Versions of Adobe Photoshop (like CC 2017) install in a different directory than c:\Program Files\Adobe\Photoshop. It might be required to copy the whole content of c:\Program Files\Adobe\Photoshop to the real Photoshop Installation like C:\Program Files\Adobe\Adobe Photoshop CC 2017
To install the Photoshop Plugin
Install Viz World Client (see Installing Viz World Client)
Double click the VizWorld-Photoshop-xxx.msi
Note: In order to support Adobe Photoshop 32 bit and 64 bit, there are two different installers, (i.e. x86 and x64). Ensure you have the installer which matches your Photoshop version, also a bundle installer is available for installing required dependencies, and provides the option to choose which Photoshop plugin version to install (i.e. x86 and x64).
Click Next
To configure the Photoshop Plugin
Launch Adobe Photoshop
Click File->Script→Viz World Setting
Enter the machine name of your Viz World Server
The configuration file being used is located in C:\Program Files\vizrt\Maps\Photoshop if you need to edit the configuration manually.
