Viz World User Guide
Google Maps Profiles
Starting with Version 17, Viz World supports Google Maps as tile provider. Google Maps supports different profiles, a default set of profiles is installed with Viz World. The set of profiles can be customized by editing GoogleMaps_Profiles.xml (default location: C:\ProgramData\vizrt\Viz World\Settings), but please note that the same xml file has to be used if a saved *.tpl file is used on multiple clients/servers, otherwise the wrong profile may be used when loading a saved map or template.
For a full list of possible options when editing the profiles, please refer to https://developers.google.com/maps/documentation/tile/.
The following profiles are installed by default:
Satellite
Shows only the satellite images, no labels or overlay
Map
Shows a 2D map with labels
Map (Large Labels)
Like "Map", but with larger labels
Hybrid
Combines the satellite images with the labels overlay
Hybrid (Large Labels)
Like "Hybrid", but with larger labels
Terrain
Shows the elevation data with labels overlay
Terrain (Large Labels)
Like "Terrain", but with larger labels
