Viz World User Guide
Version 17.0 | Published March 11, 2019 ©
Photoshop Plugin
The Viz World Photoshop Plugin is used to integrate Viz World and Adobe Photoshop files. Maps created with the Photoshop Plugin will create a new file with separate layers for every feature and detail on the map.
Note: The Photoshop Plugin must be installed separately, see Installing Photoshop Plugin.
Working with the Photoshop Plugin
Once the plugin is installed, you will be able to open Map Editor Classic from within Photoshop.
In Photoshop, go to File > Scripts and you will see the Viz World options.
The options that the plugin adds, are:
Viz World Map Editor
Opens Map Editor Classic.
Select a TPL, style, and so on, then browse and add details to your map.
After making your selections and clicking OK, a new Photoshop file will be created with all the layers of the different features and details on the selected map.
Viz World Refresh Map
Opens Map Editor Classic with the selections and map from the previously generated Photoshop file.
Modify your selection, add details to the map, and so on.
After making your selections and modifications and clicking OK the changes will be applied to the existing Photoshop file instead of creating a new file.
Viz World Save As Geotiff: Save the file as a GeoTIFF file (a TIFF file which includes georeferencing information)
Viz World Setting: Opens the settings window
Photoshop Layers
The Photoshop Plugin creates 5 layers in your Photoshop file. The following two layers are always created:
All Layers (a raster image of the final selected map)
Base Map (a raster image of the land and sea without any selections)
The remaining three layers can be configured in the Viz World Settings in Photoshop window.
To open the Viz World Settings, go to File > Scripts > Viz World Setting
Server Name: Viz World Server Host name
Layer 1/2/3: The Photoshop Plugin creates 5 Photoshop Layers. Three of these layers can be configured here by selecting the features that should be included.
