Viz World User Guide
Region to Texture
The plugin can be found in the folder: Viz Artist 3: Built Ins -> Container Plugins -> Maps.
The plugin is used to simulate shadow effects for 3D regions. This is achieved by creating a texture of a region’s contour. The plugin works in two modes: by creating a single texture that applies to all regions in the scene or by creating multiple textures that applies to each individual region.
In order to work with a single texture the plugin must be placed on the Region Holder container.
In order to work with multiple textures the plugin must be placed on a container above the 3D Region container.
Properties
Dynamic Shift: Shifts shadow texture more when Navigator is farther away. This could be used to better see the shadow from farther distances.
Dynamic Shift Amount: Sets the extent of the Dynamic Shift.
Attach to Light: When enabled, light direction will be considered according to the positioning of the shadow texture. When disabled, Shift Direction allows you to manually set the direction of the shadow.
Light ID: Sets the ID of the light to be considered.
Texture Size: Sets the size of the shadow texture. The larger the texture, the better is the visible quality; however, it also requires more rendering time.
Blur Amount: The extent to which the texture will be blurred to resemble the appearance of a shadow.
Shift Direction: Sets the shift direction of the shadow manually and according to the region. This setting can only be used if the Attached To Light setting is disabled (Off).
Shift Amount: Sets the amount of shift.
Working with Region to Texture
To create a simple Region to Texture scene
Add the Map Builder Plugin plugin to the Scene Settings
Save the scene
Open the Map Builder Plugin editor and click Launch Wizard
This will open the Map Builder. Note that it may open behind Viz Artist.
From the Choose Scene Type dialog box select Navigator
Click the Base Map
This will open the Viz World Maps Editor
Select a stylesheet for your map and click OK
Click the map for Destination 01
Click the Browse Map button (see Map Tool Bar) and select two regions (e.g. Trentino-Alto Adige and Lombardia in Italy) and click OK
Click Build
Save the map template file to your desired location (e.g. C:\Temp\Maps)
Once saved, the map scene will be generated
For creating a single texture do the following:
Navigate the scene tree to the Region-Holder container found under object -> MapAndHops -> GeoReferenceMap -> Holders ->
Add the Region to Texture plugin to the Region-Holder container
For creating multiple textures do the following:
Navigate the scene tree and split the Region__<name> container found under object -> MapAndHops -> GeoReferenceMap -> Holders -> Region-Holder -> Destination-n
Add a new group as a sub-container of the Region__<name> container
Add the Region to Texture plugin to the new group container
Open the Publish To Design editor and click the Publish and Refresh button
To adjust the textures, split the merged region containers and adjust the settings available in the Region to Texture editor
