Viz World User Guide
Fade Texture
The plugin can be found in the folder: Viz Artist 3: Built Ins -> Shader -> Texture.
The FadeTexture plugin is used to apply soft edges to a texture and to crop the texture.
Curve: The plugin has three plugin editor views that enable the different Curve control options:
Constant: Texture edges are controlled separately but no softness is applied to the texture edges.
Spline: Texture edges are controlled separately and a common softness value is applied to all edges.
Note: If an edge is not cropped, the softness will affect the edge.
Uniform: All texture edges are controlled together with a fixed softness value applied
Crop Top: Sets the crop value for the top of the texture.
Crop Bottom: Sets the crop value for the bottom of the texture.
Crop Left: Sets the crop value from the Left of the texture.
Crop Right: Sets the crop value for the right of the texture.
Fade: Sets the softness value for the edges of the texture.
Uniform Crop: Sets the crop value for all edges of the texture (fixed softness will be added to all edges).
