Viz World User Guide
Version 17.0 | Published March 11, 2019 ©
World Map Editor Shortcuts
         Where you are  |
         Shortcuts you can use  |
         While in detail map editor  |
         Esc - Cancel edits Enter - Save edits  |
         While in detail list editor  |
         Esc - Cancel edits F2 - Start edit Multiply - Fit to detail Divide - Center to detail Minus - Remove detail  |
         While on a list feature  |
         Multiply - Fit to feature Divide - Center to feature Plus - Add feature Minus - Remove feature  |
         While in preset edit mode  |
         While in shape edit mode  |
         Esc - Cancel edits Enter - Save edits Del - Delete shape Multiply - Fit to shape  |
         While on first look list  |
         Esc - Clear filter  |
         While on main view  |
         Ctrl + O - Open project browser Ctrl + S - Save favorite  |
         While pan tool selected  |
         Ctrl - Zoom tool while key pressed  |
         While zoom tool selected  |
         Spacebar - Pan tool while key pressed  |
         While shape tool selected  |
         Ctrl - Zoom tool while key pressed Spacebar - Pan tool while key pressed  |
         While street tool selected  |
