Viz World User Guide
3D Line Shader
The plugin can be found in the folder: Viz Artist 3: Built Ins -> Shader -> Maps.
The 3DLineShader is used by the 3D Map Setting Plugin plugin to draw the borders using the parameters set in the various 2D Label plugins. The plugin has no parameters and it is added automatically when adding a 2D Label object to the scene tree.
