Viz World User Guide
Hop It
This is a utility plugin which connects the specific design with a hop. It is used when the designs (e.g. labels, regions etc) were not generated from the hop you want to connect them to (or from no hop at all).
This connection can either be done using manual mode or automatic (based on searching all hops locations and connecting to the one which is closest).
The 3 plugins that are influenced are Hop Sync, 2D Label and Label It.
