Viz World User Guide
Version 17.0 | Published March 11, 2019 ©
Server System Requirements
Minimum configuration:
CPU: Intel Core2 CPU, 2.0 GHz
Memory: 4GB
Hard disk space: A full installation requires about 2 GB free disk space. Optional data packages will require between 4GB to 500GB free disk space.
Recommended configuration:
CPU: 2 x Intel i7 CPU (or equivalent Intel Xeon processor)
Memory: 16GB
Hard disk space: A full installation requires about 2GB free disk space. Optional data packages will require between 4GB to 1000GB free disk space.
Note: When more than one server will be run on a single machine it is necessary to use the recommend system configuration described above. See Server Allocator Configuration.
Server Operating Systems:
Microsoft Windows 7/10 (64-bit, 32-bit)
Windows Server 2008R2/2012R2/2016
Also note that fast and multiple CPU cores are the most important component of WoS.
