Viz World User Guide
Version 17.0 | Published March 11, 2019 ©
Map Designer Toolbars
The Map Designer has two toolbars, and most of the functions are the same as the Map Editor Toolbar. The functions that differ are described in this section.
Horizontal Toolbar
The horizontal toolbar is the same as the Map Editor Toolbar, with the exception of:
New Project: Create a new map template (see Getting Started)
Open Project: Open existing map template files.
Save Project: Save the current map template file.
Save Project As: Save the current map template file as a new file.
Vertical Toolbar
The vertical toolbar is the same as the Map Editor Toolbar.
