Viz World User Guide
Version 17.0 | Published March 11, 2019 ©
Working with the OSM Downloader
To install the OSM Downloader
The OSM Downloader must be installed alongside the Viz World Server. This is done by installing Viz World Client components on the server.
Run the Viz World Client installer
Select Custom
Select the Viz World Server Config component
Click Next
Click Finish
To configure the OSM Downloader
Before the open street maps can be downloaded and used by your designers you need to configure the Street Data location.
Tip: Both tools can be started from: C:\Program Files\vizrt\Common\Maps
Run the Viz World Server Configuration tool
Connect to your map server
Select the Maps -> Locations section to configure the Street Data location
Run the OSM Downloader tool
Set the Destination folder to match the Street Data location
To download open street maps
Before you start to download open street maps you need to have a Vizrt FTP account, aswell as have the software installed and configured.
Make sure you have a connection to your map server
Enter your Vizrt FTP account credentials and click Connect
Browse and select data
Click Add
to add data to your download queue
When done, click Download
Tip: Before attempting to connect, make sure the destination folder is configured correctly to match whats configured for Street Data location in Viz World Server configuration, and user has write privilege to that folder.
