Viz World User Guide
Map Layers
The plugin can be found in the folder: Viz Artist 3: Built Ins -> Container Plugins -> Maps.
The MapLayers plugin is used to expose map layers to an external application. Map layers are labels, regions, and so on.
Properties
Mode: Defines the layer maps mode Static and Dynamic.
Static: Enables maps to be imported to Viz Artist’s image library and saved with the scene.
Dynamic: Enables pyramid maps to be loaded from the cache and temporary folder. When the CWMClient plugin receives a new map, all layers will be updated.
Texture Compression: Sets the compression level for the texture (DTX5 is the highest compression level, which is less texture quality).
Texture Quality: Sets linear for using the same image resolution in the entire zoom range, or Mipmap to change resolution according to the distance from the image (managed automatically in Viz Artist).
Edited Layer: Sets the layer number for editing. Each layer is then assigned map properties to display.
Active: Activates or disables the selected layer.
Container: Assigns the container for holding the created layer map.
Flags: Enables (On) the requested property to expose the map property or feature in the selected layer. Flags refer to all the settings from Base Map to Overlay Data.
Build Tiles: Builds the map layers.
