Viz World User Guide
Shadow Agent
The plugin can be found in the folder: Viz Artist 3: Built Ins -> Geom Plugins -> Maps.
Shadow Agent is an agent for the Shadows parameters covered by the scene plugin Label Manager Plugin.
Properties
Render With Camera- this parameter defines for which camera shadows will apply:
All- shadows will be rendered on all cameras (Compatible with previous versions).
Label- shadows are rendered only for the defined off screen labels camera.
Map- shadows are rendered only for the defined map camera.
Shadow- shadows are rendered only for the defined shadows camera, as defined in the 3DLabelsManager plugin (Shadows tab).
