Viz World User Guide
Version 17.0 | Published March 11, 2019 ©
Getting Started with Map Editor
Once you have the Viz World Client installed you can start the Map Editor and connect to the Viz World Server. Once connected you will be able to open existing design projects.
To start the Map Editor
Normally the Map Editor will be launched from Viz Trio, Viz Artist or Viz Pilot.
To connect to Viz World Server
Note: When the Map Editor is launched from a Vizrt application (e.g. Trio, Artist, Pilot), it will automatically connect to the server that has been configured within that application, rather than the server configured within the Map Editor.
Start the Map Editor
Click the Settings button
Set the Viz World Server hostname. If not specified, the Map Editor will connect to localhost.
Click Save
