Transfer Clips From Viz One
This section details how to transfer and download video clips from a configured Viz One.
To transfer and download a video clip from Viz One, Viz One must be integrated and configured with Viz Artist/Engine (see the Viz One and Authentication pages in the Configuring Viz section of the Viz Engine Administrator Guide and the Viz One Deployment Guide).
To Transfer Viz One Clips
Do the procedure Transfer Clips From Viz One or Transfer Clips From Viz One. When, in the procedure, a video clip is to be added click
In the Viz One Uri drop down box, select a Viz One to import from.
Enter a search parameter (Viz One files are not shown until an entry is made).
Locate the required file. A preview of the clip is shown in the browser window.
Click Transfer. The video clip is transferred from Viz One and downloaded to the local video clip library (see Transfer Clips From Viz One).
During transfer, the Transfer button (5) in the Viz One Browser is inactive. To add several clips from Viz One simultaneously, add more Clip Channels. When correctly configured, the traffic light icon to the right of the drop-down menu is green (2). If the Viz One integration has been incorrectly configured, the tool-tip for the traffic light icon displays a problem description.
When set to On, the transfer status for each clip channel shows as a progress bar in the Viz One Transfer Status pane. This pane’s visibility depends on the Mediaftp (File Transfer) and Fsmon (File System Monitor) services being installed and running, and that the Viz One (MessageQueue Server) is correctly configured. Please refer to the Viz Engine Administrator Guide for detailed information on how to configure and install these services.
