CFX Jitter Color
The CFX Jitter Color animates a jittering effect on the color of the container.
Note: This plug-in is located in: Built Ins -> Container plug-ins -> ContainerFx
CFX Jitter Color Properties
Anchor Horizontal: Sets the anchor point for the containers on the horizontal plane.
Anchor vertical: Sets the anchor point for the containers on the vertical plane.
Use Axis: Defines on which axis or axes the containers scale to create the jittering effect.
Lock Axis: Applies the same Min, Max and Randomness settings to all axes when enabled. If you disable randomness, these parameters are visible for each of the axes and must be set individually.
Min: Sets the minimum scaling for the containers.
Max: Sets the maximum scaling for the containers.
Randomness: Sets the intensity of the jittering movement.
