Fabric Shader
images/download/attachments/41798879/ico_fabricshader.png
On a dull surface, the impression of detailed surface structure is created by using bump mapping. The structure is defined by a normal map. A highlight is placed along the edges of the object to increase the impression of fabric surfaces.
images/download/attachments/41798879/psh_rtt_fs_sx.png
Note: This plug-in is located in: Built Ins -> Shader -> RTTAdvancedMaterials
Fabric Shader Properties
images/download/attachments/41798879/psh_rtt_fs_er.png
  • Velvety (Limb) Parameter: Controls the strength of the velvety effect at grazing angles of view.
  • Bump Height: Manipulates the height of the created bumps and wrinkles on the surface.
  • Bump Map/Normal Map: Is the texture that defines the surface structure with encoded normals.
  • Technique: Shows a list of available techniques.
    • Standard_Bump: Is a technique has to be used with geometry that has no standard UV texture coordinates and normals.
    • Binormal_Bump: Is a technique should be used with geometry having texture coordinates and normals.
