Blend Image
Use this plug-in to blend two images in different ways.
Note: This plug-in is located in: Built Ins -> Shader -> Filter
Blend Image Properties
-     Image: Image placeholder. Reset removes the image.
-     Mode: Available blend modes are: -     Blend: Ordinary picture blending.
-     Darken: Uses the base or blend color, whichever is darker, as the destination color.
-     Lighten: Uses the base or blend color, whichever is lighter, as the destination color.
-     Multiply: Multiplies the base color with the blend color. The result color is always a darker color.
-     Screen: Multiplies the inverse of the base and blend color. The result color is always a lighter color.
-     Color Burn: Darkens the base color to reflect the blend color by increasing the contrast of the base and blend color.
-     Color Dodge: Brightens the base color to reflect the blend color by decreasing the contrast of the base and blend color.
-     Overlay: Screens or multiplies the colors depending of the base color.
-     Soft Light: Darkens or lightens the colors, depending on the blend color.
-     Hard Light: Multiplies or screens the colors, depending on the blend color.
-     Add: Brightens the base color to reflect the blend color by increasing the brightness.
-     Subtract: Subtracts the base and blend colors.
-     Inverse Subtract: Same as subtract but inverses the base and blend colors.
-     Difference: Subtracts either the base color from the blend color or the blend color from the base color depending on which color has the greater brightness value.
-     Inverse Difference: Same as difference but inverses the base and blend color.
-     Exclusion: Similar to the Difference mode, but lower in contrast.
-     Blend: Blends the image with the object.
-     Position X and Y %: Positions the image on the object.
-     Scale X and Y %: Scales the image.
-     Wrap: Wraps the object with the image. Available options are: -     Repeat: Repeats the image.
-     Clamp: Clamps the image (no repeat).
