Text FX Scale
images/download/attachments/41798412/ico_tfx_scale.png
The Text FX Scale plug-in allows you to create a scaling animation of the characters.
Text FX Scale Properties
images/download/attachments/41798412/pc_tfx_scale_e.png
  • Anchor Horizontal: Sets the anchor point for the characters on the horizontal plane.
  • Anchor Vertical: Sets the anchor point for the characters on the vertical plane.
  • Use Axis: Defines on which axis or axes the characters scale.
  • Lock Axis: Scales the Begin- and End the same for all the axes when enabled. If you disable the parameter, Begin and End must be set for all the axes individually.
  • Begin: Sets the initial size of the characters.
  • End: Sets the ending size of the characters.
