Control World
The ControlWoC plug-in allows you to expose a set of properties to the operator. The control is a replacement for the Control Map plug-in with much more options and on-the-fly feedback from Viz Artist/Engine.
Note: The two controls are not compatible. The new control with not work with Viz Pilot, and is only a part of Viz Artist/Engine 3.3 and above.
The control can expose different fields based on the container it resides on. When tabbing to the control (in a navigator scene) the camera jumps to map location and all feedback (exact camera position) is immediate.
Control World Properties
Client Mode: Sets the client mode to Full or Simple. When selecting a map, this opens the full or simple map client in the control application.
Input: Sets the exposed properties. The field is based on the input from the NavFinder plug-in; however, you may also manually change this field.
