System Time
The System Time plug-in creates a variety of time and date settings based on the system time. This plug-in adheres to the standard IEEE Std 1003.1, 2004 Ed.
System Time Properties
-     format (aAbBcdDHIijlmMpSUwWxXyYzZ/:,.): Sets the format of the system time.
-     Language: Sets the language format of the system time. Options: -     Default (system specific)
-     English
-     German
-     Norwegian
-     Seconds offset from system clock: Sets the number of seconds the system clock should be offset (default is 0).
-     Hours offset from system clock: Sets the number of hours the system clock should be offset (default is 0).
-     System time zone: Sets the system time zone.
-     Show Time Zone: Shows the result of the system time zone.
-     Lower Case Text: Shows all text in lower case.
Time Zone: tzn[+|-] hh[:mm[:ss] ] [dzn]
-     tzn: Time zone name, e.g. PST
-     hh,mm,ss: Offsets from the local timezone to UTC (not the reverse). -     For time zones ahead of the set one, the time difference is negative.
-     For time zones behind the set one, the time difference is positive.
-     dzn: Daylight-saving-time zone, e.g. PDT
Examples: EST5EDT, PST5PDT, GST-1GDT
