Viz Vectar User Guide
Switcher Modes
Many Viz Vectar models support two different Switcher modes, allowing you to choose which one is best suited to your need for a given program and environment.
The standard Switcher interface provides control over your main Program video output using the familiar Program/Preview row method.
For less complex productions, the Switcher’s convenient Express mode simplifies the process. This one-button operating mode will be especially welcome in environments where volunteers or less experienced operators are involved.
Tip: Support for switching using a touchscreen has been provided. Just tap a source’s viewport to instantly send that input to Program output using the current background transition (if any).
To select the current operating mode, click either the SWITCHER or EXPRESS tab provided at right in the horizontal bar immediately above the Switcher pane.
