Viz Vectar User Guide
Genlock Connection
The Genlock connector on the backplane is for connecting a house sync or reference signal (often a black burst signal supplied specifically for this purpose). Studios often use this method to synchronize equipment in the production pipeline. If your equipment allows you to do so, you should genlock all cameras and Vectar. To connect the genlock source, supply the reference signal from the house sync generator to the Genlock In connector (See Configuring Genlock regarding genlock configuration).
