Viz Vectar User Guide
Managing Macros
The Macro Configuration panel has management features such as folders, rename, clone, and hotkey assignment, as well as Import and Export (use these to copy macros to other units, and for backup).
Tip: Premium Access membership unlocks additional and very useful import/export file format options for macros, including JSON, Excel (.xlsx), and even a working Javascript (.js) example.
Session Macros
It’s easy to keep macros designed for use with a specific production organized and accessible, thanks to the Session Macros folder in the Macro Configuration panel. Macros in this group are exposed within that session only (or new ones based on it, if the operator uses template sessions).
