Viz Vectar User Guide
Rack Mounting
Viz Vectar is designed for convenient mounting in a standard 19” rack (mounting rails are available separately). Please keep in mind that cooling is a very important requirement for electronic and digital equipment.
We recommend allowing 1.5 to 2 inches (4 to 5 millimeters) of space on all sides for cool (comfortable room temperature) air to circulate around the chassis. Good ventilation at the front and rear panel is important, and the system also requires ventilated space above the unit (1RU minimum is recommended).
Tip: When operating your system in a road case for mobile production, it’s best to do so with both the front and back covers (of the road case) removed.
When designing enclosures or mounting the unit, supplying good free air movement around the chassis as discussed above should be viewed as a critical design consideration. This is especially true in fixed installations where the unit is installed inside furniture-style enclosures.
