Viz Vectar User Guide
Macros and Automation
Macros smooth out your workflow, reduce complex operations to a single button press, and make it easier to produce sophisticated programs. They provide many opportunities for both workflow streamlining and creative applications (macros can also reduce or eliminate embarrassing operator errors).
One of the hardest things about live switching is keeping up with the action. We’re only human, limited as to how fast our fingers can move, recall and perform important sequential steps, and so on. Macros are the answer to that dilemma. Record any sequence of events as a macro and play it back with one click. Alternatively, trigger it with a keystroke, control surface operation, or HotSpot.
images/download/attachments/68851657/Image_346.jpg
Macros can do almost anything; Preload and play content, modify audio settings, automate complex switcher sequences or perform synchronous operations. The compelling usefulness of macros justifies the prominent Macros menu placement in the Dashboard at the top of the Live Desktop.
images/download/attachments/68851657/Image_347.jpg
Click Macros to show a menu containing a Configure Macros item. This opens a large panel that allows to you create, organize, and even edit macros.
This section contains information on the following topics and procedures:
