Viz Vectar User Guide
Control Surfaces
This chapter introduces the Viz Vectar control surfaces, helping you to see how they complement your system and bring added ability to your production setup.
The discussion also covers how to properly connect your live production system to the control surface.
Viz Vectar provides unrivaled live production power. With a matching control surface, all that power is right at your fingertips.
Two Viz Vectar control surfaces have been prepared for varied requirements. In large measure the functionality provided, and workflow is identical, regardless of which you use. Vizrt dual row panel is a large and powerful four-stripe unit, delivering precise control over your program, allowing you to quickly and confidently produce your show. Vizrt quad row panel is its more compact sibling.
