Viz Vectar Plus User Guide
Version 1.3 | Published November 18, 2022 ©
Configuring Video Inputs
Video inputs appear as monitors in the Live Desktop’s monitoring section.
Monitors
Individual monitor viewports on the Live Desktop can be flexibly assigned to different Switcher sources and outputs.
Working with Monitors
Complete monitor layouts can be stored and recalled using tools in the main menu, Workspaces.
To create a monitor
From the menu bar, select Workspaces.
Monitoring layout presets are listed at the top of the menu A through D.
Select the layout labeled A under Multiview 1 (if it isn’t already check-marked).
By default, this default monitoring pane shows individual viewports for the various Switcher sources.
To continue to assign sources, either
Select Configure from an input monitor’s (right-click) context menu
or -
Move your mouse over the viewport (for example) INPUT 1.
A Configure button (gear icon) appears at lower right.
Click to open a tabbed settings panel.Tip: A quicker way to access the Input configuration panel: Double-click the viewport (for a touch-screen, tap the viewport with two fingers).
Click the Source drop-down for a list of sources. Black and other local system resources are listed first under the Local heading. Additional NDI sources discovered on your network are listed below.
For NDI sources, selecting an entry completes the connection. If you choose an local system resources, further selections may be required.
The Format field defaults to Auto-Detect. Generally, this option suffices. For other sources, select the correct format.
Close the Configuration panel for now (click Close, or click outside the panel to close it).
Continue to configure additional video sources in the same manner.
You can now view the video inputs you have configured among the Live Desktop multiview monitors.
Video Router Inputs
To configure a video router input
To select which router input will be transmitted to the Switcher input, right-click on the Switcher row button for the video input where the router is connected (see Input Connections).
