HP Z4 G4
This section describes how to setup a HP Z4 G machine with the different cards provided by Vizrt. More details about the HP Z4 G4 can be found on HP’s website: HP Z4.
Info: Only newer Matrox Boards like X.mio3 and DSX.LE4 are shipped with Z4 G4 workstations. Older videoboards are not tested by Vizrt.
PCI Configuration
Slot |
Configuration |
Slot 1 |
Graphics Card only! (Single / Dual Slot) |
Slot 2 |
Used if Dual Slot GPU is installed |
Slot 3 |
Possible Expansion Card Installation: G-Sync |
Slot 4 |
Expansion Cards (see Slot 3, except Matrox Video Board) |
Slot 5 |
Matrox AES Audio |
Default Hardware
Tower 4RU
CPU Render: 1x Intel Xeon W-2133 (3.6GHz 6-Core)
CPU Control: 1x Intel Xeon W-2102 (2.9GHz 4-Core)
RAM Render: 32 GB DDR 4 (4x 8GB)
RAM Control: 16 GB DDR 4 (2x 8GB)
SSD1: 256 GB S-ATA (Operating System)
SSD2: 512 GB M.2 NVMe (Data and Clips, only in Render PC)
RAID Controller: Intel SATA/NVMe M.2
Power Supply: 1x 750W 90% Efficient
BIOS Configuration
During Post, press F10 to access BIOS Setup.
Go back to Advanced Tab > Secure Boot Configuration.
Select: Legacy Support Disable and Secure Boot Enable.
Go back to Advanced Tab Overview.
Click on Build in Device.
Increase PCIe Idle Fan Speed to: 0050.
Press ESC and save Configuration.
Info: Certain third party vendor drivers require secure boot to be disabled to install properly.
