Control Buttons
This section contains information on the Controls Buttons, which include the Play and the On Air buttons.
Clapper Board: Shows or hides the Director Control Pane window. -
Back: Jumps to the beginning of the animation in the scene. -
Play: Starts the animation of the scene. -
Stop: Stops the animation of the scene. -
Continue: Continues the animation after it stopped at a stop point.
Render Preview: Shows or hides the VGA Preview window. The keyboard shortcut for activating or deactivating this window is SHIFT + BACKSPACE. The state of the VGA Preview window depends on how the Render preview default setting in the Video Output section of Viz Config is configured: -
Inactive: Does not display by default.
Active: Displays by default.
Fullscreen: Sets the On Air window to screen size.
Fullscreen preview: Enables Fullscreen preview on a certain Monitor. -
Unreal Engine Control: If AUX rendering is turned on, Unreal Engine Control can be enabled:
Performance Editor: Shows or hides the Performance Bar. -
System Information: Shows or hides the On Air Information Panel window.
