lo_lock
The table lo_lock contains information used to restrict editing access to a template. The template database locks at template level. I.e. only one user may edit a single template at any time.
The lock table also contains rows used to store timestamps for last updates within a single gallery or the database overall. These values may be used to poll the database for changes. These timestamps are stored in the lo_updatedate field.
Note that the lo_insertedby field is used to identify the lock type:
Template - This is a true lock, locking the corresponding template. The template is identified by the value in the lo_recno column which contains a foreign key to the te_recno value in the te_template table.
Gallery - Contains a timestamp when the corresponding gallery was last updated. The gallery is identified by the lo_recno which for gallery types contains a foreign key to the corresponding gallery, ga_recno in the ga_gallery table. The foreign key is a function of the lo_recno value as follows:
ga_recno = 10 - lo_recno
Database - Contains a timestamp when the database was last updated.
Other values are deprecated.
Name |
Type |
Allow Null |
Description |
lo_recno |
integer |
No |
Primary key Also used to identify either a gallery or a template depending upon the lock type. See description above. |
lo_ga_recno |
integer |
Yes |
Optional foreign key referencing the gallery owning the lock |
lo_ga_name |
varchar(32) |
Yes |
The name of the gallery owning the lock |
lo_insertedby |
varchar(32) |
No |
Contains the lock type. Either Template, Gallery or Database. See description above. |
