AV Automation Devices - Audio
Viz Mosart is capable of connecting a variety of Audio Mixers available from several different manufacturers.
Select the correct Audio Mixer from the menu for your broadcast environment. AV Automation handles the following:
Audio Mixer, a backup MIDI Audio Mixer
Loudness Control from Junger
Audio Mixer
Use Audio mixer: Check the box to enable the audio mixer functionality.
Audio mixer type:
Calrec: Calrec Serial Protocol
DHD: RM4200-D Fa. DHD
LAWO RMNOPL: RemoteMNOPL protocol
LAWO ZIRKON: RAS subset protocol
SSL: Light Broadcast Automation protocol
STAGETEC: Stagetec RAS protocol
STUDER_3000: For audio mixers supporting the MONITORA protocol
WHEATSTONE: Wheatstone Mixer Automation Protocol
YAMAHA_O2: For audio mixers controlled through MIDI control change and parameter change
STUDER VISTA: Control of the Studer Vista series via the Ember protocol
Serial (Calrec, Lawo, Studer, etc.): Serial port connected to the audio mixer (when Serial radio button is selected).
TCP/IP: Hostname (or IP address) and port to communicate with the audio mixer (when TCP/IP radio button is selected).
Backup hostname and port (Lawo): Hostname (or IP address) and port to the backup audio mixer console.
Set user labels on console: When selected, user labels on the Lawo console are overwritten.
MidiCh (Yamaha): MIDI channel assigned to the audio mixer.
Midi Output port (Yamaha): System MIDI port to communicate with the audio mixer.
Default fade time: Time in frames for fading open faders with the manual fade function (CTRL+F).
Default snapshot: Snapshot to recall when starting the automation (MIDI parameter change).
Audio effect server: Name for the Audio effect fader. This fader will open if effect transitions are used.
Send reset command on connect: Used for STUDER3000 SW 2.2, or lower. Recalls a default setup for the Mixer panel.
Visible audio faders: Maximum visible faders in AV Automation.
Use sound player: Check box to enable connection to the Audio Player.
Host: Hostname or IP address to the computer running the Audio Player.
Default directory: Directory for the audio files (on the Audio Player’s PC).
AV Automation Audio Mixer Compatibility Table
CAL REC |
DHD |
LAWO RMNOPL |
LAWO ZIR KON |
SSL |
STAG ETEC |
STUDER 3000 |
WheatStone |
YAMAHA O2 |
STUDER VISTA |
EUPHONIX |
Serial |
x |
x |
x |
TCP/IP |
x |
x |
x |
MidiCh |
x |
Midiport |
x |
Hostname |
x |
x |
x |
x |
x |
x |
x |
x |
x |
Port |
x |
x |
x |
x |
x |
x |
x |
x |
x |
x |
Backuphost name |
x |
BackupPort |
x |
Faderinputoffset |
x |
Useemberprotocol |
x |
Comportaudiomixer |
x |
x |
x |
x |
x |
x |
Loudness Control
Use loudness controller: Check the box to enable loudness control.
Loudness controller type: JUNGER T*AP
Triggers/levels: Name of triggers or loudness levels, one for each line. These will appear in a tool-tip menu in the Template editor, and must correspond to the configuration in the loudness controller(s).
Channels: Fixed values. For Junger T*AP there are 4 stereo channels per host. Connections to the audio faders are configured in A/V Setup/Edit/Audio config/Loudness channel.
Host:port: Hostname or IP address and optional port number for each controller.
