Using AV Automation
AV Automation is the device handler for Viz Mosart. This application communicates with all the different devices such as cameras, video servers, vision mixers and also has the tools to configure these devices. The template editor, where you can define and customize the templates, can also be found in this application.
AV Automation Main Menu
Devices:
Preferences: Open AV Automation Device Properties
Template editor: Open Template Editor
A/V Setup: Open Audio and Video Setup
Show recording: Open a dialog to start and stop recordings
Change password: Create or change the Template Editor Password
Show:
Show MVCP Control: Deprecated
Instrumentation Panel: Open the Mosart Instrumentation Panel
Studio setups: Select the template set to use for the current show
Standby: Lists all configured devices and their status
Idle: Enabled if AV Automation is in idle mode
