General Advice on System Operations
Rebooting and Restarting - General Notes
All software system must be restarted now and then. This applies to both the operating and Viz Mosart system.
Rebooting Machines
The actual reboot frequency cannot be accurately determined up front, but good practice dictates rebooting all Windows PC's and Servers at least once a month.
Should any ill effects occur periodically with this monthly reboot interval, it is advised to reduce the interval to once a week. Likewise, if there still are issues, the next step should be daily reboots. In this case, steps should be taken to determine the problem cause.
Application Restart
For restart of the Viz Mosart Applications, we have not firmly stated any interval, as this depends on the actual practice in the stations, the connected equipment and the total workflow.
Just like for system reboots, good practice dictates restarting the Viz Mosart Applications at least once a month.
Viz Mosart Application Updates
Vizrt updates the Viz Mosart applications regularly, in which we may add new features or fix some reported bugs. We strongly encourage our customers to review our Release Notes for each release and assess whether you should upgrade to the latest versions. If so, you could easily do this using the Viz Mosart Installation Administrator. In case of a fallback to a previous version, you can resolve such an event equally fast and easy. If necessary, you may facilitate some rapid test runs in between other transmission schedules.
As long as your operation is running according to your expectations, not hampered by whatever causes we have experienced for our previously published fixes, or as long as you don't need the new functionality that we have introduced with the new release, or when your servers are running in network isolation, there may not be an absolute need to do an upgrade of the application.
Windows Updates
The interval for running Windows updates depends on the environment. If the PCs are accessible from other zones, both Windows and antivirus updates must be done just as any other machine in the station’s network.
Based on the possibility of antivirus runaway, it is not recommended to run real-time virus scanning during transmissions. 24/7 stations must give this possible issue thorough considerations.
Note: There might be a ~30 second delay when starting AV Automation. The cause of this phenomenon, which typically happens just after some configuration, is the need for a Windows Update to be run. Consult the proper Microsoft procedure to update Windows via downloaded files if it is not permitted to connect to the Internet.
Viz Mosart Main/Backup Server Testing
Our recommended usage pattern is to alternate between main and backup every day, to make sure that the vital backup server is ready to take over the day you really need it. This way, you are continuously testing the backup function.
