Video Wall Connection Strings
Video wall connection strings are used by AV Automation. This section contains the following Connection String types:
Note: For general information on connection strings, see Video Server and MAM Connection Strings.
Watchout Connection String
This connection string is used for WATCHOUT video walls.
Modes of Operation
The driver may operate in any of three different modes. (For the sake of simplicity, assume that at least two commands are to be performed in one operation.)
default: A driver operation sends the commands one after the other. It waits for WATCHOUT to respond finally (or time-out) before sending the next command. If a command fails, the rest is skipped. The advantage is that when the driver operation finishes, the entire operation is complete (or has failed). However, as driver calls may arrive in different threads, and therefore simultaneously or overlapping, problems may occur. (The driver is made for performing (sending and feedback-waiting) one command at a time.)
SequenceRecallAndMixes: A driver operation queues the commands to be performed as a unit (without interference from other such units), possibly at a later time. The problem mentioned above is solved, however at the cost of the driver operation possibly finishing before the commands are complete.
SequenceIndividualCommands: A driver operation queues the first command (to be performed without interference from other commands). If successful, the next command is queued, and so on. This may be useful if WATCHOUT is able to keep several shows loaded at the same time (and is able to use the run timeline argument to choose between them).
Examples
AV Automation Connection String:
AuthenticateTimeout=[authenticateTimeout];BufferSize=[bufferSize];BusyNonCommandTimeout=[busyNonCommandTimeout];BusyTimeout=[busyTimeout];GetStatusThreshold=[getStatusThreshold];LoadTimeout=[loadTimeout];PingInterval=[pingInterval];PingTimeout=[pingTimeout];Port=[port];ReconnectInterval=[reconnectInterval];ResetAnyway=[resetAnyway];ResetTimeout=[resetTimeout];RunTimeout=[runTimeout];SequenceIndividualCommands=[sequenceIndividualCommands];SequenceRecallAndMixes=[sequenceRecallAndMixes];Server=[server];UseGetStatus=[useGetStatus]Example:
Server=192.168.97.129;AuthenticateTimeout=200;RunTimeout=40Connection String Properties - Watchout
AuthenticateTimeout: Integer>0. The time (in ms) allowed for WATCHOUT to process an authenticate command and respond with Ready. Default 2000.
BufferSize: Integer>0. The maximum number of bytes to receive from WATCHOUT at a time. Should be set at least as large as the longest conceivable WATCHOUT response. Default 1024.
BusyNonCommandTimeout: Integer>0. The time (in ms) allowed for WATCHOUT to return to normal operation after a non-command Busy. Default 10000.
BusyTimeout: Integer>0. The time (in ms) allowed for WATCHOUT to increase the % of otherwise equivalent Busy responses. Default 60000.
GetStatusThreshold: Integer. The highest acceptable value of the 3rd parameter of the Reply feedback to the getStatus command (General health status of the cluster; 0: OK, 1: Suboptimal, 2: Problems, 3: Dead). Default 1 (Suboptimal).
LoadTimeout: Integer>0. The time (in ms) allowed for WATCHOUT to process a load command and respond with Ready. Default 10000.
PingInterval: Integer>0. The time (in ms) between ping commands sent to WATCHOUT. Default 10000.
PingTimeout: Integer>0. The time (in ms) allowed for WATCHOUT to process a ping command and respond with Ready. Default 10000.
Port: Integer>0. The port to connect to. Default 3039.
ResetAnyway: true/false. Whether reset commands are always sent before run commands even if not present in the RecallAndMix argument. Default false.
ResetTimeout: Integer>0. The time (in ms) allowed for WATCHOUT to process a reset command and respond with Ready. Default 10000.
RunTimeout: Integer>0. The time (in ms) allowed for WATCHOUT to process a run command and respond with Ready. Default 10000.
ReconnectInterval: Integer>0. The amount of time (in ms) to wait to reconnect after a failed connect or authenticate. Default 10000.
SequenceIndividualCommands: true/false. Whether the driver should operate in that mode. Has no effect when SequenceRecallAndMixes=true. Default false.
SequenceRecallAndMixes: true/false. Whether the driver should operate in that mode. Default false.
Server: String. The DNS name of WATCHOUT. Default localhost.
UseGetStatus: true/false. Whether the Ping operation should use the getStatus command instead of the ping command. Default false.
