Version Numbering
Installation folders are named with the Viz Mosart version number. All files inside that folder will also carry the corresponding version number attached to the filename.
Version numbers have the following syntax:
Major.Minor.Revision.Build (for example 3.4.5.12345)
Where:
Major.Minor.Revision denotes the Viz Mosart Version Number
Build denotes a patch number
Example: Installers\3.4.5.12345\MosartServerInstaller.3.6.1.12345.msi
Here we can see that the computer has a folder for the Viz Mosart 3.6.1.12345 release, containing associated installers.
Every significant code change of Viz Mosart will result in a change to the Viz Mosart Version Number. This will be increasing either the major, minor, or revision number.
Patches are identified by having a higher build number than the remainder of the files.
