AutoTake Timings
An Autotake template element presents a detailed representation of the timing that will employed at playout. A summary of the various alternatives, showing which template parameters affect timings for an Autotake, is presented below:
Autotake Transition with No Effects
Tat = td1 + tm1 - tm2
Tat = Time for autotake, relative to t=0
tm1= mix delay, story item 1
td1= duration, story item 1
tm2= mix delay, story item 2
td2= duration, story item 2
For clips: td = clip duration - post roll
Autotake Transition with Effects and Mix Delay
Tat = td1 + tm1 - tm2- te2
te2 = effect duration, story item 2
Autotake Transition with Effects and no Mix Delay
Tat = td1 + tm1 - te2
Mix delay considered part of effect duration
