Common Graphic Controller Properties
The Graphic Controller Properties that are available, depend on the Graphic Type of the controller. The controller properties common to most graphics types are described below.
Additional properties for each Graphic Type are described in Overlay Graphics Types.
Active signal:
The Active status signal is a signal sent to AvAutomation containing on-air status of a graphics engine.
Distribute status: When true, signals the on-airs/usage status of an engine to AvAutomation. Status message will be sent to AV Automation log area, Manus console and OverLayGraphics log area.
Delay (frames): Sets the delay of the graphics active status changed event signal. Using a negative value for the delay will disable the functionality, i.e. Distribute status is false.
AvAutomation will perform the following actions: -
sets the DSK if this is enabled ("Control DSK from OverlayInterface" is checked on the Switcher preferences page and the switcher can set DSK)
executes direct takes configured on the Switcher preferences page in the section "Overlay DirectTake control"
cuing the graphics in certain conditions (the rundown story item is in preview, the channel template used has a Graphics device setup, the engine is not in use, the channel is not on-air)
Description:
Graphic Type: Select the brand and type of graphics
Id: Unique number id identifying the graphics controller. Shall be unique among all defined controllers.
Name: Optional, defines the name of the server.
Replace takeout logic:
Enabling takeout logic will read out the Transition Logic context of elements and use this to either suppress take out or re-take items. Take outs will be suppressed if another item with the same context was taken before the scheduled for take out action. Take outs will be replaced with re-takes if the item scheduled for take out replaced an item with the same context. Only for Vizrt graphics with transition logic.
Delay (frames): Delay when checking for duplicate ‘take in’ commands in the next element
Enable: Use transition logic aware take in/out commands
Note: Also see the Graphics Profiles Tab for other controller settings.
