Audio Mixer Configuration Files
This section contains the Audio Mixer types:
Calrec TCP/IP Configuration File
The Calrec TCP/IP configuration file is named AudioMixerCalrec.xml.
<?xml version="1.0" encoding="utf-8" ?> <DeviceConfig name="AudioMixerCalrec"> <Properties> <!-- If set to true, controller stays connected when in idle. Note that in a redundancy setup,on both main and backup Viz Mosart servers this option must be set to false. --> <item name="ConnectedWhenIdle" value="false"/> <!-- If set to true, AvAutomation waits for Ack after sending command to the driver. Note that this configuration will overwrite the general configuration with same name from AvAutomation settings (Ctrl+Shift+S). If commented, the general configuration from AvAutomation will be taken into consideration.--> <item name="AudioWaitForAck" value="true"/> <!-- Max wait time for receiving Ack --> <item name="AckTime" value="199"/> <!-- Wait time before trying to reconnect --> <item name="ConWait" value="1000"/> <!-- Interval to set fader levels on the audio driver. If set to 0, the operation will not be re-scheduled. Note that this configuration will overwrite the general configuration with same name from AvAutomation settings (Ctrl+Shift+S). If commented, the genral configuration from AvAutomation will be taken into consideration.--> <item name="AudioPollInterval" value="0"/> <!-- Interval to send an heartbeat to the driver (number of counts until next heartbeat will be sent). Set this to -1 to disable sending the heartbeat. In this case, AvAutomation will not be able to detect when audio driver connection goes down, for example. --> <item name="HeartbeatInterval" value="1000"/> </Properties> </DeviceConfig>SSL Configuration File
The SSL configuration file is the same as used for Calrec TCP/IP Configuration File
