Media Administrator Commands
Media Administrator is a console application, and responds to free text commands. The following table outlines available commands:
add <clipname> <index>: To manually add a clip to the list of clips currently monitored. This function is typically used while testing the installation.
delete <index>: Deletes a monitored clip with the given index.
dumpclips <filename>: Outputs a list of all monitored clips in an XML format. Outputs to console if a filename is not given.
dumpprofiiler: For testing only. Shows timing information.
exit: Exits the Media Administrator.
flushactionqueue: Flushes the internal action queue. I.e. all pending actions are executed.
help: Outputs a help messages showing all available commands.
listactionqueue: Outputs the pending list of actions to be executed.
listclips: Outputs a list of all monitored clips.
listservers: Outputs a list of all configured media servers.
mmhost <hostname>: Sets the hostname of the Manus Administrator. Default: localhost
postroll <roll>: Sets/displays the current value of the post roll.
reconnect: Reconnect to all configured media servers. Typically only one video server is connected.
reconnectadmin: Reconnects to the Manus Administrator.
refresh <n>: Refreshes the status for all monitored clips <n> times. I.e. a request is made to the server for all clips. This function is typically used to test the installation. Default <n> = 1.
search <regex>: Issues a clip search to the video server. The regex is a regular expression for clip names. This function is typically used to test the installation.
set <property>=<value>: Sets a property value. If no property is given, a list of all supported properties is displayed. Currently the following properties are available
NextClipAttemptDelay- Delay in seconds when to automatically verify presence of non-existing clips. Note that most video servers support asynchronous notifications making this functionality not necessary.
NextServerAttemptDelay- Delay in seconds when to try to reconnect to a video server. I.e. if connecting to a video server is not successful this delay determines the time to wait before a new connection attempt.
NextPingDelay- Delay in seconds when to ping the connected video servers. Pinging is used to detect whether the servers are valid.
MonitorClipInterval- Interval for monitoring clips. A clip is polled for changes as long as any of its attributes changes.
settings: Opens the Media Administrator - Properties Editor.
verbose: Toggles verbose output. In verbose mode, more information is logged to the console.
version: Outputs Media Administrator version and some system information.
