Settings Editor - iNews
To open the frmSettings XML Editor, open the Manus Administrator console, then type settings followed by <ENTER>.
Open sub-sections by clicking the section headers:
Configuration
Auto preview overlays: List of graphics destinations supporting preview of overlay graphics. I.e. DSK will enable preview of all overlay graphics with handler=DSK. Default: Empty = no preview.
Auto Take Offset: Value of an offset for the autotake function. Default: 0.
Default Handler Name: For all graphics that have no handler name, a default one will be assigned, and this can be configured using DefaultHandlerName setting in Manus Administrator. Default: DSK.
Default Lower Third Out Behaviour
Force clip editorial time: Always show Editorial time in GUI. Default: False.
Frame rate: Set from the timing information in the NRCS. Is always 30 (most commonly used) or 29,97, even if the actual frame rate of the stations video is 60 or 59,94.
Note that even clip servers send timing information at 30 or 29,97 although the actual video frame rate is 60 or 59,94. -
Ignore updates if nothing changes: If set, will ignore story update from NCS if the updated story is assumed to be equal to the current version of the story. Default: False (no NCS story updates are ignored).
Keep story status on updates from NCS: Enable this to keep played out stories gray if the story is updated in the NCS. Default: False.
MetaData creator priority: Select between Newsroom editorial time, MAM duration or full video clip length. Separate IDs with commas. Override the priority of where the timing information of a video file is taken from. Use the name of the Media Administrator entry. Special names are NCS (for information from the NCS) and GLOBAL (global values from media object). If Empty, Viz Mosart will insert NCS as the first and GLOBAL as last entries. Default: Empty.
Minimum clip length: This value sets the minimum visible length of an offline clip in a story in the GUI, as soon as Viz Mosart receives clip information the visible length will be updated. Default: 5 (ss:ff).
MyPort: The port used for other Viz Mosart applications to connect to the Manus Administrator. Default: 8085.
Network exclude: Manus Administrator will automatically enter idle mode on network failure. This property is a CSV list of network names to ignore when monitoring networks. Default: Empty (monitor all networks).
Network include: Manus Administrator will automatically enter idle mode on network failure. This property is a CSV list of network names to monitor for network failure. Default: Empty (monitor all networks).
Offset secondary events with mix delay: Secondary events will follow primary events mix delay. For example, a lower third element will be delayed the same mixdelay as the package it is supposed to be keyed on. Default: False.
Pause Timing On First Break: When enabled, any first story with a single break template will not start the rundown timing (Elapsed rundown duration). The timing will start when the next story is taken.
Preload Accessory Cue Delay: Defines the delay between end of cue the next item and when a pending preload/pretake accessory shall be executed. Time given in frames. Default = 6 frames. I.e. the accessory preload/pretake functions shall take place after the cue operation is done in AvAutomation with an additional and configurable delay of PreloadAccessoryCueDelay frames.
Reset AutoTake on 'Clear Loop': Enable this to automatically disable the autotake mode when using the clear loop function from the GUI. Default: True.
Server description: User defined descriptive name of server that is displayed in the Timing Display.
Should Upgrade: For internal use only. Should not be manually changed. Default: False.
Startup in idle mode: Default: True.
Story Compare Ignore Attributes: Used for debugging purposes only. Default: Empty.
Templates allowing graphic pretake: List of template types that will allow pretake of overlay graphics elements. Default: PACKAGE, VOICEOVER.
Transitions on Accessories: If enabled, allow transition effects on accessory templates. If disabled, any transition effects will be removed from accessory templates when translating newsroom XML into Mosart XML. This is how it has been, historically.
Use Take Out Logic: Enables the CG takeout logic. When two CG graphic objects with the same graphic IDs are next to each other, the first one is not taken out, only “take in” on the second object will be executed. Default:False. When True, enables the takeout functionality for overlay graphics.
UseItemStatusToNCS: Enable this to send online offline CUE/PLAY/STOP status to the NCS. Default:False.
Configuration file paths
AvConfig: The path to the XML-file containing the audio and video mappings defined in the AV Automation application. Default: c:\channeltemplates\avconfig.xml.
Channel templates: The path to the file containing the Viz Mosart templates built in the AV Automation Template Editor. Default: c:\channeltemplates\channeltemplates.xml.
Manus Directory: The path to the folder containing copies of the internal Viz Mosart rundown. Default: c:\manus.
Newsroomsettings: The path to the XML-file containing the mappings from newsroom system commands to Viz Mosart templates. Default: c:\channeltemplates\newsroomsettings.xml.
Crossover
Crossover Auto Take On Switch Offset: Offset in milliseconds to pre-take an autotake when the next story item is after a crossover switch. Positive value will trigger the autotake before the given duration of the story item. Negative value will trigger the autotake after the given duration of the story item.
Crossover Set Next On Switch Delay: Delay of sending set next story from the server running the show when taking control. Default: 500 (milliseconds).
Default
ConnectionString: The connection string of the crossover, example: controller=IP address, client=crossover. Default:“”
Default item durations
Break: The minimum length given to the BREAK template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 100 (milliseconds).
Camera: The minimum length given to the CAMERA template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 125 (milliseconds).
DVE: The minimum length given to the DVE template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 125 (milliseconds).
Full-screen-graphic: The minimum length given to the FULLSCREEN GRAPHIC template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 125 (milliseconds).
Item: The minimum length given to any template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 100 (milliseconds).
Live: The minimum length given to the LIVE template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 125 (milliseconds).
Lower-third: The minimum length given to the Lowerthird template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 100 (milliseconds).
Telephoneinterview: The minimum length given to the PHONO template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 125 (milliseconds).
Video Clip: The minimum length given to the CLIP template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 125 (milliseconds).
iNews configuration
Default Rundown: Deprecated.
Encoding: Character encoding of the iNews story items. Should match the encoding used in iNews. Default: Encoding for the operating system's current ANSI code page. Other values: UTF7, UTF8, UTF32, UNICODE, BIGENDIANUNICODE, ASCII.
FTP Port: iNews FTP port.
Ignore Send Cue Status To NCS For Offline Clips: Enable this flag to prevent the NCS for receiving CUED or READY statuses of offline video clips. Default: False.
Password: Password of a valid iNews FTP account. Normally password to a valid iNews user with access rights to the iNews FTP server.
Refresh Media On NCS Update: Setting to true will trigger clip refresh for all clips that belong to a story being updated, normally via story updates from NCS. This ensures that all clip information is synchronized. Default: False.
Server: Hostname or IP address where the iNews FTP server is running.
Time to delay initial devices while waiting for NCS to add story: Delay of displaying the loading rundown when rundowns are being published to Viz Mosart. Default:500 (milliseconds).
User Name: User name of a valid iNews FTP account. Normally name of a valid iNews user with access rights to the iNews FTP server.
Working Directory: Initial directory in iNews. Viz Mosart will give access to all rundowns stored hierarchically within this directory. Default: SHOW.
iNews Web Service configuration
Web Service Connection: Connection string. Example: WebServiceServer=localhost; iNewsServer=10.211.112.104; iNewsUsername=mosart; iNewsPassword=mosart; SendUpdatesStatusForAllItems=true; ClearStatusWhenRundownReloaded=true.
Logging
Ignore verbose events filter: Semicolon based list of events to ignore in the log when using verbose logging. Default: Empty (log all events).
In use: Enables or disables the logging of events from the Manus Administrator to the logfile. Default: True.
Log level: Sets the detail level of logging to the log file: 0=normal, 1=warnings, 2=errors, 3=info, 4=detailed.
MSMQ Log limit: Value to identify when the application should dump the log queue to file. Default: 4023.
Pass verbose events filter: Semicolon based list of events to log when using verbose logging. Default: Empty (log all events).
Path for MMLog: The path where the Viz Mosart log is stored. Default: MosartLog.
Trace internally: Enables or disables internal tracing to console, for debugging only. Default: False.
Use verbose logging: Enables or disables verbose logging. If UseLogging is set, verbose increases the details sent to the log. Default: False.
Manus configuration
Default Manus: This value selects the default rundown to use. If the setting UseDefaultManus is set to True, the system will load this rundown on startup.
Manus expiration time: Time in days to keep Manus Administrator files. I.e. files older than ManusExpirationTime will be deleted when Manus Administrator is started. Default: empty (no clean up).
Manus keep file pattern: If ManusExpirationTime is given this property allows a list of file search patterns for files to keep in the Manus Administrator directory. I.e. "TEST*;DEMO??.xml" will keep all files starting with “TEST” and all DEMO??.xml files where ‘?’ denotes a wild character. Default: empty (no files to keep). Note ‘;’ is used to separate the file search patterns.
TestManus: Rundown to be used for maintenance purposes.
Use the default selected manus: When enabled, will automatically initialize the rundown given in the DefaultManus setting. Default: True.
Read speed
Read Speed: Number of words read per minute by the anchor. (By default, words are taken to be the parts of text separated by space characters. See the setting Use character for read speed word below.) This is applied to prompter text to determine duration of announcement and thus the length of the green camera bar and the green part of the voiceover bar in the Viz Mosart GUI. Default: 145 (words per minute).
Note: Note: This is a fallback read rate which is only used when the NCS System fails to provide a ReadRate of its own. This function can be tested by changing any readspeed=”xx” to readspeed=”” on an item in a local Manus file.
Use character for read speed word: If True, each character will count as a word for the purpose of calculating the spoken duration of prompter text, cf. the setting Read Speed above. This can be useful in languages like Chinese and Thai, where the space character is not used to separate words. If False (the default), words are separated by space characters.
Template database configuration
ConnectionString: The connection string for the Template DB. For example, for MySQL: server=<hostname>; User Id=<user>;Password=<password>; database=mosarttemplatedb.
Default inserter: The name to be used for the insertedby and updatedby columns in the Mosart Template Database.
Name of provider: The provider name for the Template DB. For example, MySql.Data.MySqlClient for MySQL.
Use template database: When true, enables the Template DB functionality, i.e. importing template type aliases from DB to newsroomsettings.xml at startup, and exporting newsroomsettings.xml to DB after saving newsroomsettings.xml. Default: False.
