Server Maintenance
This section describes various maintenance aspects of Viz Mosart, and is divided into the following:
Server File Structure
The Viz Mosart Server stores files in different locations on the workstation as indicated by the list below:
Location |
Definition |
C:\Program Files (x86)\Mosart Medialab |
Mosart applications. Various sub-directories for components such as Mosart GUI, Mosart Server and more. Either \Program Files or \Program Files (x86) |
C:\channelTemplates |
XML-files defining the channel templates. Will normally contain minimum channeltemplates.xml, newsroomsettings.xml, AVConfig.xml |
C:\manus |
The Run-down (playlist) files fetched from the Newsroom systems. |
C:\MMLogs |
Default location for Log-files. Rotated. |
C:\ProgramData\Mosart Medialab\ConfigurationFiles |
System-wide configuration settings (XML) |
C:\Users\<USERNAMEHERE>\AppData\Local\Mosart_Medialab |
User-specific application configuration files |
Note: The list above is an example and may differ for various installations and Windows versions. Refer to the corresponding succeeding subsections for further details.
Static Configurations
This is configuration that is static and common to all versions of Viz Mosart installed on the computer. Any upgrades will not overwrite any the content mentioned below but new configuration parameters will be appended if present.
Type: Configuration
Backup: Yes
For Support: Yes
Content:
Video and audio setup
Story templates
User Configurations
This is configuration that is dependent upon the location and version of the application. Typically under the location there is a set of directories each referring to a particular installation of a Viz Mosart application. For example, for the Media Administrator:
%UserProfile%\Local Settings\Application Data\Mosart_Medialab\MMConsoleAdmin_2007.exe_Url_<*>\<version number>
Any upgrades will create a new subdirectory name with the corresponding version number and do a merge from the current version.
Location: %AppData%\Mosart_Medialab or %UserProfile%\Local Settings\Application Data\Mosart_Medialab
I.e. for a particular non-roaming user: C:\Documents and Settings\<User>\
Local Settings\Application Data\Mosart_Medialab -
Type: Configuration
Backup: Yes
For Support: Yes
Content: Settings for all Viz Mosart Applications, for example the content of the various settings dialogs.
Viz Mosart Applications and Services
This is the location where the Viz Mosart installers will place program files.
I.e. for a default English language setup: C:\Program Files(x86)\Mosart Medialab -
Type: Applications
Backup: Yes* - Most of the executables (.exe) files have corresponding configuration files. Normally the content in there is static and is not changed during an upgrade. Nevertheless, custom configuration is possible.
For Support: No
Content: One or several subdirectories. One for each Viz Mosart installer.
Manus Administrator Repository
The Manus Administrator repository contains all rundowns that have been loaded into Viz Mosart from the newsroom system.
All rundowns are stored in an XML format, making it possible to extract rundown information to use for other purposes, for example video clip usage statistics.
Type: Rundowns
Backup: No* - Only for selected rundowns.
For Support: Yes
Log Directory
By default, log files are stored in C:\MMLogs.
Type: Log
Backup: No
For Support: Yes
Content: A set of log files from Viz Mosart applications.
Note: For support purposes, collect all log files with timestamps that cover the period of time where an issue was discovered.
Files for Backup
All locations stated in Server File Structure should have a safety copy taken whenever changes are made to the active Viz Mosart Server.
It is recommended to copy files and corresponding directories to a common share, outside Main and Backup Viz Mosart Servers, marked with Viz Mosart version and dated when the backup was performed.
Alternatively, you can use the Backup Files function in the Viz Mosart Installation Administrator.
File Purging
The Manus Administrator Repository and the Log Directory, have a built in mechanism for purging files.
The content of these directories will grow unless a maintenance procedure is established. This can be configured in the Manus Administrator Configuration program by writing settings, and then setting the value ManusExpirationTime to any number of days.
The Log system is preset to a 60 days retention period, but this can be changed.
